Huntsville trunk system on the PSR500
blueangel-eric
Emporia, KS
Is the Huntsville Trunk system that came pre-programmed on the PSR500 up to date or do i need to start fresh? thanks
scanrfan
Birmingham, Al
Huntsville TRS System
Check the RR file for the Huntsville system and compare the frequencies and TGID's with what you have in your scanner. If you use a software package to program the radio, see if you can run a "hard copy" of the system as it's loaded into your radio then it will be much easier to check against the RR file.
