Huron County P25 TRS
mtindor
OH/WV DB Admin
Carroll Co OH / EN90LN
Awesome.. Will be nice to be able to look through any new transmissions from unknown talkgroups to try and figure out the purpose of the talkgroup.
If there isn't a lot of activity on it, you might want to make sure your offline-alert is set to some value significantly higher than the normal (I forget what the default is) so that you don't get false positives in your email claiming that the feed is offline -- when in fact there just haven't been any transmissions for a while
Thanks for setting that up.
Mike
dth1958
Norwalk, Ohio
Sounds like TG 25624 might end up being Greenwich PD
  • 20210118_114642Huron_Co_Huron_Co_TRAFFIC__TO_25624_FROM_3904102.zip
mtindor
OH/WV DB Admin
Are you confident of that? 7xx units, 705 and 701 I think it was. Are 7xx Greenwich? I wouldn't know since I"ve never monitored them.
And if anybody reading this thread does know the typiccal unit numbers in use by all the various law enforcement, let me know so that I can add it to the Huron County main wiki. Right now there is just EMS information in the wiki (the county wiki, not the trunked system wiki)
Mike
dth1958
Norwalk, Ohio
I found that recording in my files before setting it up to stream
i have set it up to send them all now
i see its being archived now
unit1231
Ohio
Your fears seem to be founded. I get it. All my county LE (podunk Carroll Co) is ENC also. Makes you wonder just what they need to hide.
m
I am in your Area. From what I can gather poking around on here if I was to purchase a Scanner capable of monitoring P25 MARCS including Carroll, Tusc, and Stark County Simulcast, UHF, and VHF what I am seeing most often is the SDS100 and SDS200. Are those the best options or are there some better? I want to monitor all 3 simultaneously.
mtindor
OH/WV DB Admin
If you truly want to monitor one or more simulcasts, then you can't go wrong with an SDS100 or SDS200 (other than the fact that they are expensive). Despite what you may read on the forums, they do exactly what they are supposed to do with simulcast sites -- they copy them fine. I think that you will enjoy an SDS100 (handheld) or an SDS200 (base/mobile). I don't have an SDS200 but would like to have one. Both of them have the same capabilities though as far as monitoring a combination of conventional frequencies and multiple disparate trunked systems at a time.
Mike
HOLEBILLY
Mike
I do know for sure Wakeman pd uses 5xx The chief of police in Wakeman is 501.
dth1958
Norwalk, Ohio
These are some notes i have been writing down
hearing county dispatch for monroeville greenwich and wakeman
rid seem to be alphabet order
a
b 3901xxx bellevue pd unit # 4119 4198 4201 4213 4319
c 3902xxx county (huron) so unit # 01 05 09 10 12 16 17 19 21 22 23
d
e
f
g 3904xxx greenwich pd unit # 1136
h
i
j
k
l
m 3907xxx monroeville pd unit # 981 983 984 985 988
n 39xxxxx new london ?
39xxxxx north fairfield ?
3911xxx norwalk pd unit # 126 132 142 153 156 176 184 185 193 194 195 218
o
p
q
r
s
t
u
v
w 3916xxx wakeman pd unit # 501 531 534
3917xxx willard ENC
wa8pyr
Technischer Guru
Lead Database Admin
Ohio
Listening to the archives I heard a whole bunch of 500 units calling 3900 on 25624; if the 500 units are Wakeman PD, that would be my guess.
dth1958
Norwalk, Ohio
update : unit #'s heard on tg's
unit #'s heard on tg #,s
a
b 25680 3901xxx bellevue pd unit # 4101 4119 4198 4201 4213 4215 4319 4518 5115 5116
c 25632 3902xxx county (huron) so unit # 01 05 09 10 11 12 14 15 16 17 18 19 20 21 22 23 (414 inmate transport?)
d
e
f
g 25632 3904xxx greenwich pd unit # 1110 1120 1128 1133 1136
(1110 3904302 heard on dispatch ? tg 25593)
h
i
j
k
l
m 25632 3907xxx monroeville pd unit # 931 981 983 984 985 988
25752 3911xxx norwalk pd unit # 054 122 126 132 142 153 156 176 184 185 193 194 195 211 218 911 934 411
o
p 25632 3902611 plymouth ?
q
r
s
t
u
v
w 25632 3916xxx wakeman pd unit # 501 514 515 521 528 530 531 533 534 537 581 911
3917xxx willard ENC
dth1958
Norwalk, Ohio
Huron County (P25) - Archives
25624 (Unknown/Unknown
Listened to last night's traffic sounds like 25624 is going to be used for traffic for the police departments of dispatched by the county :
3904xxx Greenwich PD unit # 1110 1120 1128 1133 1136 1196
3907xxx Monroeville PD unit # 931 981 983 984 985 988
3908xxx New London PD unit # 703 705 710
3916xxx Wakeman PD unit # 501 510 514 515 521 528 530 531 533 534 537
cbg1031
New London Ohio
Any way you could add those feeds to brodcastfy?
