Was going to do this really long complicated very detailed post of info but that's overkill so I'll simplify it a bit.
If you can buy something from eBay Canada, it's worth checking into. My recommendation is to look for business class hardware from HP or Dell like HP Elitebook laptops or EliteDesk desktops or Dell Latitude laptops or Precision desktops. I don't recommend consumer class hardware, haven't in a few decades and I see no reason to alter that stance.
Also, only deal with sellers (individuals or companies) that have a 95%+ positive feedback or better, that offer actual return policies of some kind (even if it's just 14 days that's better than some sellers who don't offer anything at all so read the fine print on every item page, top to bottom, carefully).
Right now one of the most popular series of laptops in the used market are the HP Elitebooks and the Dell Latitudes, especially the Latitude E6420/E6430/etc series. The models you'd find on eBay Canada would be ones from companies that had huge fleets of these kinds of laptops, which are business class machines with magnesium or aluminum bodies and chassis and are rock solid hardware. When companies upgrade their fleets that do it thousands of laptops at a time so other companies buy up their entire fleets for a lump sum price and then offload them (after some reconditioning if needed) on eBay Canada (and here in the US obviously, I just say Canada since that appears to be where you're located).
I just realized when I was quoting the price ranges in my post above that I didn't take that into consideration - I was quoting prices in US dollars so I suppose if you adjust that accordingly (give or take $25-50) then it'll be in the ballpark.
As for in your neck of the woods, I just looked at the London Ontario CA listings for craigslist and, wow, you weren't kidding: there's only like 8 computers listed in the owner's category. Just for comparison, the Las Vegas listing for the owner's category gets 8 computers listed
every hour... geez, what a difference.
Final word (Disclaimer - the following is personal opinion only and should be taken as such):
Avoid HP Pavilion laptops if you can in all respects, just run in the opposite direction of 'em. I am speaking only for myself here, but after working on computers since the 1970s, that is the single most horrendously terrible series of laptop products I've ever encountered in all of those years. I've repaired a few hundred of them and I'm sick of dealing with that crap hardware. Case in point: the entire dv series from years ago in the 2000/4000/6000/8000/9000 series with Nvidia GPUs on them were defective, every last one of them. Now, while the consumer owning one of those models might not directly experience problems that doesn't dismiss the fact that they were all shipped from the factory with substandard solder which caused GPU failures over time and rendered the machines basically useless. Most of those models were made 8-9 years ago so they still exist in the used computer market.
The newer Pavilion dv series machines like the dv5, dv6, etc, are somewhat better but I am ruined for Pavilion hardware, period, and so I will recommend them to be avoided at all costs.
They are the one particular line of computers I simply won't touch anymore, even for repair jobs, I just won't do it. HP EliteBook laptops (and ProBooks) are damned nice hardware, however.
Typical used pricing for such business class laptops made in the past 5 years are roughly $250-325 and that's Canadian dollars. I'm looking at the ebay.ca site right now and see a bunch of Dell Latitudes in that range which are rock solid machines. One thing to take note of is if you intend to play games - I have no idea if you will or not so I'm presenting the info - is that most of these business class laptops have the Intel GPUs (the HD 3000 or HD 4000 onboard graphics because they're part of the chipset/CPU). If you look for one that has an Nvidia GPU (for Dell Latitudes) or an ATI/AMD GPU (for HP EliteBooks) that will give you much better graphics performance that can play some games with medium graphics settings.
If you're a hardcore gamer then such laptops aren't going to cut it but then again for such gaming oriented machines the prices will be higher to begin with.
I could go on for hours with recommendations but the best thing overall is make sure you're buying from a reputable seller and read all the fine print in the ads, top to bottom, the whole page. If you do choose something local, the advice I presented above about checking it out prior to handing over the cash for the purchase is still recommended.
Good luck...
