HYT TC700 professional radio
dellsea
Asia
Frequency -
UHF: 350-390MHz 400-450MHz
420-470MHz 440-490MHz
VHF: 136-174 MHz
RF Power Output: 5W/2W/1W(VHF) 4W/2W/1W(UHF)
Audio Power Output:1W
Channel Capacity: 16
Meets MIL-STD-810 C/D/E/F & IP54
CTCSS, CDCSS, DTMF, 2 Tone, 5 Tone, HDC2400TM signalings
Wide-band Coverage
High Speaker Volume
Versatile Safety Assurance
Built-in Scrambler
Whisper
Channel Annunciation
Power On Self-test
Communication Range Alert
Software Upgradeable (optional)
Embedded Message & Serial Number
Rental Setup
Emergency
Call Function
Battery Power Indicator
For more informations,pls goto: http://www.hyt.cn/02product/detail.asp?prodid=4316
Thunderbolt
Global Database Administrator
Ann Arbor, Michigan
This radio has some really interesting band coverage:
Frequency -
VHF: 136-174 MHz
Looks like there is a lot of commercial activity on UHF and even VHF in China. With the economy booming in that country, I can see where a lot of businesses would have a need for two-way radio communications to better manage their fleet and/or personnel. Moreover, I see the area between 390-400 MHz is not covered. I have heard this is where governmental TETRA systems operate in China.
Built-in Scrambler
I wonder what type of encryption this radio uses? I am thinking it must be some type of voice inversion rather than a digital mode. That said, I wonder if business and industry companies in China are fearful that a competitor might be intercepting their communications? If so, how are they doing it?
73's
Ron
dellsea
Asia
to Thunderbolt :
I just know that this Scrambler is able to make the voice variation to others whom are not permmit to hear the contents ,but the chosen one is able to hear clearly!
K2GOG
Mid Hudson Valley
The radio only has 16 channels. THe UHF specs are different splits for variuos versions. The radio does not cover all of that all at one shot. The PLL only supports about a 50Mhz spread.
fwradio
Texas DB Admin
Fort Worth, Texas
It is available in the US. There are several HYT dealers out there. When Motorola bought Vertex and fired all of the factory reps, HYT signed them on and set up hundreds of dealers. The price can also not be beat.
Bote
know-it-all
Ft. Lauderdale, FL, U.S.A.
External spkr-mic inputs and outputs
What kind of input-output ports does the HYT TC-700 offer?
I have a guy who is trying to hook up an E&M interface on a voice gateway to one of these things and his pinouts show pins 1 & 2 not connected. I don't see how that will work without COR coming out of the radio.
He's using 3.5mm and 2.5mm plugs. I assume, like the Kenwood radios, the larger is for receive audio, the smaller for transmit audio, and they close the circuit between the two jacks to signal PTT?
Thanks!
brian86
Maryland
Relm rp7500
Relm Radio has the same radio but in diffrent band coverage. UHF 450-520Mhz and sells for under $300.
My bad wrong radio!!!!!
Josh
Auburn Hills, Michigan
HYT builds radios branded with relm...
I bought a TC3600 from eBay and could find no support from HYT or its dealers because it's not meant for the US market as the Relm RPC3600, or something like that, is the same radio, just branded with Relm.
I found the things I needed, including programming warez without much hassle from Relm dealers/people.
-Josh
