Hytera 982i to 1062 site connect
kd4efm
Florida
Has anyone put together a site connect between the 982i (v9) and the HR-1062 (a1.xx) with the 1062 as a slave
and only get 1 way audio from the 982 to the 1062, but not the other way back, 1062 to the 982?
radioopperator
I have all 982 units networked. Do you have a static IP for each unit or are you (PROPERLY) port forwarding the machines? You can DMZ the routers at each end that's how I started with my network. You need 50000-500003 and 164 and 161 ports all forwarded if you want to use XNMS remote system or just 50000-500003 if your using RDAC to monitor.
Pittsboro IN
Got this from a dealer after another sub dealer reported similar issue.
We had issues trying to link an RD982 or an HR to an MD 782 to link the repeaters on tier 2 to the
Mobile as a control link to tier 3 . Either combination gave us loss of tier
3 audio on the repeaters after several hours - Fix require rebooting the
repeaters. We were able to make it work using the old RD low power repeater.
