Hytera Custom Tones
Forts
Ontario, Canada
Does anyone happen to have a list of custom audio tones? (PTT etc). There used to be a great list over at Communications Support but I didn't save a copy. I could have sworn some were listed here as well but I'm not turning anything up. The default ones are so.... blah!
n1das
Nashua, NH
I've customized some of the tones in my PD982 handhelds, also in my UHF X1p. I set the volume of these tones to be linked to the volume control.
You define these tone up in the User Defined Tone part of the programming under Common. You enable these under Conventional>General>UI Indication to enable these tones in place of the default tones. I'm recalling all of this from memory so this might not be totally correct.
I like the Motorola Talk Permit Tone (TPT) used on Moto's P25 handhelds. It's similar to the old NEXTEL DirectConnect chirp but at a lower frequency. For the old NEXTEL DirectConnect tones, I programmed the PTT chirp, incoming DirectConnect call double beep, and the short end peep heard on the end of a received DirectConnect transmission. I also programmed the Motorola MOTOTRBO TPT in case I decide to use it.
Talk Permit Tone (TPT) in Hytera programming set to Motorola TPT (see below).
Voice End Tone in Hytera programming set to NEXTEL End Tone (see below).
I left everything else set at the default.
Analog and digital TPT delays are set at 300ms.
I had to make some audio recordings of these tones and then do some analysis of tone frequencies and durations to know what to program in the Hyteras.
Motorola P25 TPT: I like this one the best for a TPT.
910Hz 30ms
0Hz (silence) 20ms
910Hz 30ms
0Hz (silence) 20ms
910Hz 50ms
NEXTEL DirectConnect Talk Permit Tone (TPT): This is the familiar NEXTEL PTT chirp.
1800Hz 30ms
0Hz (silence) 20ms
1800Hz 30ms
0Hz (silence) 20ms
1800Hz 50ms
NEXTEL Incoming DirectConnect call: This is the Dee-Deet tone, heard at the start of an incoming DC call.
2300Hz 90ms
0Hz (silence) 90ms
2300Hz 90ms
NEXTEL DC End Tone: This is the short peep heard at the end of receiving a DirectConnect transmission.
2300Hz 40ms
Motorola's MOTOTRBO Talk Permit Tone (TPT) consists of 4 tones of 40ms duration, with no silence in between tones. It makes a warble type sound. I don't remember the tone frequencies off the top of my head right now.
Good luck.
Forts
Ontario, Canada
Thanks! I had the 910/20 one in my radio already but had lost track of the others.
Much appreciated!
KG4INW
Midlothian, VA
CPS will round these to the nearest ten but, to me, this sounds exactly like the MOTOTRBO TPT:
1569 Hz 40 ms
1046 Hz 40 ms
1569 Hz 40 ms
1317 Hz 40 ms
n1das
Nashua, NH
Those are the exact MOTOTRBO Talk Permit Tone (TPT) tones. I couldn't remember the 4 tone freqs off the top of my head.
The CPS will round them to:
1570Hz 40ms
1050Hz 40ms
1570Hz 40ms
1320Hz 40ms
Sent from my Nexus 6 using Tapatalk
n1das
Nashua, NH
I'm looking for the incoming Group call tone(s) and voice end tone(s). The incoming Private Call tone(s) would be nice too.
I've heard these tones from Motorola MOTOTRBO radios but I'm looking for the actual tone freq(s) and duration(s). A recording would be enough for me to analyze the tone freqs and durations.
I think the incoming Group Call sounds like 3 of the 4 tones in the TPT. I recall it sounds something like 1050Hz/1320Hz/1570Hz. Not sure about the duration of each tone. I need a recording of the tones to analyze it.
Sent from my XP8800 using Tapatalk
k7plt
Note sure if this is relevant anymore, but here is a list of tones that I have captured and spectrally
reproduced with a tone generator:
Vertex Talk Permit
1050Hz 20ms
0Hz 20ms
1050Hz 20ms
0Hz 20ms
1050Hz 20ms
Vertex Voice End
800Hz 20ms
0Hz 20ms
680Hz 20ms
Vertex Call End
1050Hz 40ms
0Hz 30ms
680Hz 40ms
1800Hz 30ms
0Hz 20ms
1800Hz 30ms
0Hz 20ms
1800Hz 50ms
NEXTEL DirectConnect Incoming
2300Hz 90ms
0Hz 90ms
2300Hz 90ms
NEXTEL DC End Call
2300Hz 40ms
NEXTEL DirectConnect Alert
2300Hz 150ms
0Hz 150ms
2300Hz 150ms
0Hz 150ms
2300Hz 150ms
0Hz 150ms
2300Hz 150ms
Motorola Power-Up (polyphonic)
400Hz|
800Hz| 200ms
overlap 40ms
660Hz|
990Hz| 200ms
overlap 40ms
530Hz |
1050Hz|
1570Hz|
2100Hz| 160ms
Motorola P25 Talk Permit
910Hz 30ms
0Hz 20ms
910Hz 30ms
0Hz 20ms
910Hz 50ms
Motorola MOTOTRBO Talk Permit
1570Hz 40ms
1050Hz 40ms
1570Hz 40ms
1320Hz 40ms
