Hytera HP782 Programming Question
VA3ADP
Mississauga, Ontatrio Canada
Hello everyone!
I Just picked up a new HP782 and I'm just wondering if there is any way to copy and paste my old codeplug from my hytera x1p onto my HP782?
Thank you
dazey77
The closest is to export/import the contacts and channels. Don’t believe you can bring un a whole code plug.
dazey77
It goes via excel (which needs to be installed on the programming pc). There is an option in one of the drop down menus for import and export. Channels and contacts are done separately.
if you are just exporting And importing its simple. If you want to edit the sheet, it’s either an.xls with a .xlsx file name or vice versa
(I am travelling at the mo, so can’t tell you precisely)
0xFF1E071F
You cannot copy/paste codeplug as dazey77 mentioned. Also i am pretty sure, you cannot clone from x1p to 782, cps won't allow you because those are two different radios. CPS menu `Program > Clone to radio Ctrl+F3`
But using CPS you can export channels/contacts from x1p then import to your new 782 radio.
Under CPS menu there are: `Tools > Export Conventional Channel` and `Tools > Export Conventional Contact`. Clicking these two will export xlsx file. Then using `Tool > Import Conventional Channel` and `Tool > Import Conventional Contact`, you can easily import your contacts and channel info to your new radio.
Muxlow
Super Secret
Middlesex County
Cant convert a "old" codeplug from a PD/MD series into the new H series. Have to start over from scratch.
Mentions it in the help file someplace also about it
I ran into this issue few months ago when i got my demo h series mobiles
