Hytera MD782G U1 Programming
HFD170
Hillsboro, OH
I have a Hytera MD782G U1/ I can read the radio but cannot write/ I am using the front mic connector with the USB programming cable.
Firmware is A2.00.09.004/ software CPS_v7.06.02.008.NA2/ I get Program Fail
YL3IM
KO26BX
V2 is very old FW with current one being v9. Try upgrading the device first.
lz1mak
Hello! I have exactly the same problem. Bought the radio from eBay and can not write.
In one of comments saw the link in gigaparts for update. There is a note:
DO NOT UPGRADE YOUR FIRMWARE BEFORE USING THE WIDEBAND TOOL.​
What does it mean?
Thank you
radioopperator
Why are you using version 9 CPS when you have PRE version 9 firmware? You have OLD version 7 FIRM use OLD CPS or change firmware to new if you have right cable and the skills to do it? If not use OLD CPS!!!
