Hytera MD782i
ultrajv
It might, if you use a recent scanner capable of DMR and you have sufficient signal strength. Outdoor antennas are the only way for good signals. If the Hytera has encryption enabled then nothing will work.
0xFF1E071F
can a scanner pick up this radio type hytera md782i
What do you mean I cannot get it. A scanner cannot get model name like md782i.
Hytera's voice signals generally have manufacturer id of Hytera and also hyteras data signals have MOTOROLA's manufacturer's id.
Are you asking something like this?
0xFF1E071F
:unsure: So, by using a compatible sdr and software, you can get the radio's model if it is MD782i, right?
Pittsboro IN
According to this file there is no radio type sent in the standard RF data stream but manufacturers are free to put what they desire in the PDU, proprietary data header. See section 9.2.9 on page 95 or search for 'manufacturer' in the file, there are other places to stuff data.
My thought process says an SDR might show raw data but without knowing the format it could be useless.
