Hytera: Monitor only of an XPT system
racingfan360
Hi, trying to help a colleague with an issue. He's trying to use a PD782 to monitor-only an XPT system (just like a conventional scanner). The PD782 works fine on conventional DMR systems but not a peep when monitoring the XPT system. That's despite being able to confirm settings look ok, and its sat side by side with a scanner that is receiving traffic from the XPT. Any clues? Can anyone confirm that a Hytera handheld should be able to operate in listen-only mode against an XPT system? TIA.
racingfan360
Investing further, XPT implements an Authorization Key. I know that without the key it would prevent unauthorised tx on the system. Bur am I right to assume it would also prevent rx on a Hytera HH as well?
