Hytera pd362 upgrade to I
matt131
Does anyone have firmware update to upgrade pd362 to an I unit?
dazey77
Don't think that exists. There are two variants of the pd36x, one that runs V1 firmware and one that runs v2. Separate hardware versions (The later one being the wireless charging version). I hear on the forums that the later one may being renamed to an 'i' to reduce confusion but i have no confirmation of that. Either way, an early version can't be upgraded to a later through software, its hardware changes
Sent from my iPad using Tapatalk
I have the old style that can't be upgraded. If the radio has 2 small holes just above the top left of the battery that's the old style, the newer version has pins. The way I found out is a communications error pops up when I tried to update mine.
I deleted the old CPS since we are supposed to flash every radio, now I'm looking through my backups to find CPS that will work.
here is the new version.
https://tacticalrf.com/files/PD3X2i.zip
According to yesterday's webinar the court order says Hytera cannot release any non i series radios, so everything sent for repair will be sent back as v9. They did not have an answer about my 362s when I talked to them Friday, maybe new guidance has come down since then.
