More bad advice from Ubbe. And again, it's about DMR TIII and DSD+.
Bad decodes do not produce repeated identical Aloha messages out of thin air.
DMR signals decoded with incorrect polarity change DATA messages to VOICE messages and vice versa, so you are telling us that BOTH timeslots are carrying continuous voice but being decoded as data frames because the decoding polarity is incorrect?? And that the
varying voice data (it always changes as people talk) is being decoded as
identical aloha messages??? How would the 16 bit checksums be correct so often? And why is slot 1 always decoding as CSBKs (DMR control channel messages) while slot 2 is always decoding as IDLE messages,
just like a real DMR TIII control channel signal does?
For reference, here's a decode of a local weak TIII control channel; it's identical to the OP's photo:
