Hytera X1p “Micro-mutes receiving”
nodsew
Hello,
I have a problem with mi hytera radio.
When receives from a repeater, some incoming transmisions has got micro-mutes.
I have test with other antenas and signal is ok.
All my hytera radios has got this problem. However Motorola and anytone is ok.
I think that the solution is in a parameter
of the hytera CPS, however I dont know how to solve it.
nodsew
Sounds like you have a priority background scan running.Do you have weather enabled maybe?
Frank
Yes, It sounds like when the priority background scanning is running. However the scan is OFF.
With my two hytera I heard the micro-mutes from repeater at same….So, some incoming transmisions with micro-mutes, and other perfect.
With Motorola and Anytone, no problem.
Signal ok, antenna ok, no interferences….
