Hytera X1p - Private Calls Not Triggering
mjolnir792
I'm told others were having the same issue - using HDC, I tried to initiate a Call Alert/Private Call fro a Motorola HT portable to a Hytera X1pi, using an individual unique 4 digit HDC ID. The radio doesn't decode it...but it does decode Selective Calls to a group and the ID directly no problems. Am I doing something wrong, or is there a setting I need to activate?
dazey77
I have a mototrbo DMR and an X1P but am struggling to understand what you are trying to do. This is all analogue 5-tone right? Your trying to get 5-tone IDs decoded between hytera and motorola?
mjolnir792
No, MDC-1200/HDC-1200. No 2- or 5-tone. This is all on analog operations, not DMR.
Did you figure this out? I looked at my X1P code plug to see if there were any misc settings to check like there are for DMR compatibility but didn't see any.
dazey77
I am guessing it must be an error in one of your decoders or one missing. I did try and have a bit of a go at it but didn't come to a real conclusion I am afraid.
mjolnir792
I'm trying to work with Hytera to figure out what the issue is. I am aware of someone that got it to work, but he isn't sharing, and no one I spoke with knows what to do. Every other MDC function works perfectly...group calls, transmitting IDs, decoding IDs, etc.
I tried HDC private calling between a PD682 and PD562, my PDC760 does not have HDC that I can see.
I don't get any audio on the PD562 from the PD682 but the display does show the PD682's ID.
I'll do some more testing tomorrow.
mjolnir792
Hytera's official answer: "The radio isn't capable of it". I would accept that, but I have it on good authority that there is a local vendor that did figure it out (he still isn't sharing). So now I'm confused on why a manufacturer isn't aware of what their own stuff is capable of.
I'll be back in the office next week and will try a PD782 and 982 to see if it's model related.
I don't ever recall using MDC for private calls with Motorola radios before.
