I broke the plastic tip off a Nagoya NA-771
dragon48
Boynton Beach, Florida
Will this make reception and transmit distance worse, or is the only problem that accidental eye pokes will cause more damage?
This is the piece that I broke off one of the antennas:
I am a lineman for the county.
All it does is cover the end and ~sort of~ keep you from poking your eye out. It will not impact performance, it's just a cap. Only way you'd have an issue would be if the metal inside the antenna touched something else metallic, in which chase the antenna would be electrically longer and detune it temporarily.
If you are concerned about it, you can get Plasti-Dip at most hardware stores. You can dip the end of the antenna in that and let it dry. You can get Plasti-Dip in different colors, if you want to get creative.
