I-Calls
ems170
Connecticut
If I enable I-Calls on a trunked system, do I need to still manually program a talkgroup for I-Calls as .0 or 700000 in the case of motorola. If I dont add the talkgroup what will the display show and is there a way to manually select to listen to I-Calls only.
Thank you
Matt
rdale
Lansing, MI
If you use ID SCAN - yes. If ID SEARCH - no.
To listen to I-Calls only, select I-CALL = ONLY.
