BlueCoyote
- Joined
- Dec 31, 2021
- Messages
- 5
So I recently bought a cb radio, it's an old hy-gain 1 681 (the forty channel model), and a mag mount mic, I don't yet have an swr meter, so I don't know if it's tuned or not.
I can hear just fine, but when I try to transmit, nobody hears me.
I started troubleshooting the problem, and found that no power was getting to my antenna, I even went so far as to key up the mic, and grab the antenna, to see if it shocked or burned me, but nothing happened.
Both of my fuses are good, and I can hear just fine.
When I key up my mic, the power meter on the radio goes up to a seven, and if I talk loud enough, it moves a little bit, so I'm pretty sure the final, and mic are good.
When I use a multimeter, it shows no resistance between the antenna and any metal part of the radio, including the radio mount.
My setup is (very temporary) the antenna mounted on one truck, and the radio running off the cigarette lighter in a different truck, because one truck has a steel body, and isn't currently running, and the other has a fiberglass body, and is running.
I only mention this, as I don't know if it could cause some sort of trouble with the antenna getting it's electrical ground through the coax.
I'm very new to having a cb radio, and don't know a whole lot about maintaining one, except what I could find on the internet.
I opened the radio, and there are a few components I don't recognize, but all of the capacitors, and resistors, look good, and I can't find any broken solder joints, or torn wires.
I assume there is some sort of audio processing circuit, but don't actually know what to look for, or how to test it, and I wouldn't think that would keep the antenna from receiving any sort of voltage, but I'm out of ideas, and thought I'd ask for help here,
I'll include a picture of the inside of the radio if that helps at all.
I know I could just buy a new radio, but I'd like to make this one work if possible,
If anyone has an idea of what could be wrong, and what could fix it I'd greatly appreciate the advice
