DSDPlus I Lost the FMP24 Text File
air-scan
Out of the ordinary I decided to decode Provoice (It won't trunk follow EDACS) the Provoice audio of my local EDACS system using the FMP24.scanlist however, I lost the text file for FMP24. I got it working using TCP and no monitor if no digital option (DSD+FL 2.235) I really need that FMP24 text file so I know the correct options to make sure I have it set right.
Thanks in advance
air-scan
BM82557
Berkeley Co WV
I've never seen an FMP24 text file, none of my copies of various versions has one. Maybe it was in a version before I joined FastLane.
slicerwizard
Toronto, Ontario
No FMP24.txt file that I've ever seen.
Notes.txt file has some scan list info in the DSD+ 2.18 / FMP24 2.11 section:
FMP24 v2.11
Support for AM demodulation has been added.
Use the D key to switch between AM and FM demodulation modes.
Squelch logic has been added.
Use -q1 on the command line to enable squelch.
Press Q to enable/disable squelch.
Squelch sensitivity levels are fixed:
Manual tuning: uses loose squelch / will unmute on weak noisy signals
Scanning: uses tighter squelch / will not unmute on weak signals
New FMP24.ScanList file options:
"AM" or "FM" can be used as the "protocol type" for analog channels.
"BW=<num>" can be used to select a specific RF bandwidth filter. Units are kHz.
"DELAY=<num>" can be used to specify a "wait for a reply" delay period. Units are seconds.
Examples:
118.3 AM BW=12.5 DELAY=2 Miami Tower
145.17 DMR DELAY=1.5 N2GKG
When scanning analog or digital channels, squelch logic is automatically enabled
When scanning analog channels, noise filter #1 is automatically selected
When scanning digital channels, noise filtering is disabled
When scanning only analog channels, DSD+ is not required; audio output can be routed
directly to your speakers or to a streaming application via a software-based audio cable.
If FMP24's audio output is routed to DSD+, select raw source audio monitoring mode #1
(monitor/unmute if a signal is present but no sync detected) in DSD+.
When scanning only digital voice channels, FMP24 should be TCP linked to DSD+.
When scanning a mix of analog and digital voice channels, FMP24 should be TCP linked to DSD+
and raw source audio monitoring mode #1 should be selected in DSD+.
air-scan
Well this was simple enough. worked like a champ.
Here is my FMP24.scanlist
851.3375 PROVOICE
851.3875 PROVOICE
851.4875 PROVOICE
851.825 PROVOICE
852.3625 PROVOICE
852.475 PROVOICE
852.6625 PROVOICE
852.900 PROVOICE
853.100 PROVOICE
853.300 PROVOICE
853.700 PROVOICE
853.800 PROVOICE
853.862 PROVOICE
Default 12.5khz bandwidth was adequate and i don't use delay scanning a trunked system.
