I need a UHF W9 astro spectra code plug
radiodude123
I need the capability for a W9 head on an astro spectra UHF. Either 438-470 or 450-512 will work.
S record or archive.
radiodude123
So you're reasoning for not sharing a code plug with me is just because that's something you wouldn't do !??!?!
NavyBOFH
Where idiots grow on trees
Let's explain why some are hesitant to help...
1) What you asked for is too vague to even start to help. OK, you want a "codeplug" for a W9 head UHF Astro Spectra, and then list two different band splits. Then you also ask for an s-rec for the same thing.
2) Most of what you're asking to do invokes the use of "restricted" software which is not discussed on this forum AT ALL. EVER.
Now - I know what you're trying to get done and I don't blame you since I have been there and since Motorola hasn't supported these radios in a LONG time, it is a gray area. Now I can give you some information to help you with this. For one, you need a SPECIFIC s-rec and codeplug for what you're trying to accomplish. If your radio is an R-split or an S-split model, you'll have to put THAT specific s-rec and codeplug into the radio. You'll also need to either save your tuning values or expect to go through the unit with a service monitor to get it working again.
So what you asked for is pretty much the technician's equivalent of saying "I want you to load a gun for me and I'll shoot my own foot off". If you can provide better specifics (within the forum rules) people might be able to be more helpful - but coming off as 1) needy, 2) uneducated, and 3) cocky/arrogant about your "lack of help" isn't going to help.
radiodude123
But a code plug is what I'm asking for. Nothing else ! And that is not restricted !
You can infer anything you want, but that is pure speculation !
Any code plug for a UHF astro spectra in the ranges specified will work for my purpose.
Thank you
P.S. actually I would prefer archive format and not s record !
NavyBOFH
Thank you
I wasn't ever trying to infer anything - just to try and clear up and confusion and reiterate some of the rules here so no one can ever accuse someone of talking about restricted software.
That being said, I only have a VHF W9 present in my stash of junk here. I hope someone can chime in here with some help.
Have you tried the Codeplug Supersite for it?
radiodude123
Hi Navy
Yes that is about the only code plug the supersite doesn't have ;-)
I have a UHF W9 astro spectra with a badly corrupted codeplug. Can't even read it.
I'll try anything at this point.
thanks
ledzep11
Astro spectra R split UHF W9 s record
I am in need of a UHF R split W9 s record as well. Any help is appreciated.
