I need advise on the best way to install an antenna?
ezernie
I'm going purchase an discone antenna for my RS 2052 base scanner and need some good advise on installing it. I don't want my house burned down by lightning.
I have some 1-1/4" and 1" od galv. coated pipe already that I could use.
My conditions:
-singel level ranch style w/ 5' attic space, if used inside, no more than a
20' run total
-if outside, no restrictions but want to keep it looking nice. and safe !!
-could mount mast on brick chimney in rear, above roof line, 100' run,
would this need a grounding wire ran to the ground w/stob or will the
chimney be the ground?
-could mount mast in ground away from house, bury 60' of line, 100' run
total
-could mount mast in ground beside house at room where base is, to
above roof line, 40' run max
I was thinking of the latter, use approx 33' of metalic pipe, bury about 3'
in the ground in concrete, anchor w/ brace on side of house.
Thanks in advance :D
merlin-7
Summerville,S.C.
best thing to do is look into your local codes...but ground everything to a 4' copper ground rod at min.
LarrySC
Greenville, SC
Your "latter" is the best idea. Put mast 1' into ground. Bolt mast to facia board below roofing. Use 20' of mast. That gives you a grip on the bottom and about 10' high. I've been in my house 35 years. Have two antennas bolted to shop this way and have a double decker scaffold for several other antennas. Only ONCE did I ever have an antenna show damage from lightning. The biggest danger is from a strike on the power line. I've had two of those that took out some equipment that was not protected with a MOV device. Good Luck, Larry
