I'm looking to purchase another hand-held scanner for the house. I currently have a RS Pro-96. I'm debating on either buying another Pro-96 or the Bearcat 396T. Which should I purchase and why? Thanks.
ac7xc said:You should buy the Uniden because when the new trunked frequencies are reassigned in 800 MHz rebanding you can easily upgrade the radio. The radio shack scanners can not be upgraded.
GRE scanners can't be user flashed - if a "reflash" is needed they have to be sent back to Radio Shack.junior17172003 said:Incorrect! The Radio Shack/GRE Pro 96 and 2096 will be able to be upgraded/reflashed/reprogrammed after rebanding.
The 396 can be flashed by the user.n4voxgill said:no one knows for sure the 396 can be reflashed.
n4voxgill said:no one knows for sure the 396 can be reflashed. In every post Uniden has included the fine print at the bottom saying they can't guarantee it will work after rebanding.
The main reason I see for buying another Pro96 is you only have to maintain one data base on win96 and can quickly make changes to both scanners.
Most likely be reflashable to work after rebanding.nexus said:The Project manager for Uniden who is in charge of development of these scanners happens to frequent this forum as well as other yahoo uniden based forums. Very active at providing information and his statements on radio reference have indicated that the BCD396T would reflash by the user to accept the rebanding structure. And that wasn't the only scanner he listed either.
Joseph11 said:Isn't the format of the data the control channel sends to the radios going to stay the same? I thought the only thing that was going to change was the channel number sent out. It doesn't sound like a matter of the scanner's hardware, but the software on it. If the BCD396T can be reflashed to change how the FTO feature works, I would think it could be reflashed to work after rebanding. Uniden just has to release a firmware update.
Dubbin said:BTW where the heck did you go in the middle of our playoff discussion? I was thinking you got mad at me because the Pistons ended Millers career![]()
