I need help. Discriminator tap
KafxRadio
Hello.I have a pro 164 and I want to do the discriminator tap.Can someone help me please?I need help, step by step.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Agreed. Depending on what you are trying to do. getting an el-cheapo RTL-SDR might be a better solution. Mike
a417
Having a TP even without a post makes it easier than some to gain discriminator point access.
Carefully soldering a wire & resistor to a marked TP point (albeit a surface trace) and securing it like you need to do with the -164 is loads easier than some which requires attempting to solder on to the attached leg of a chip and then removing/replacing components like you would with a BCXLT180/280 (if you were also attempting to use the factory output due to not wanting to drill a hole in the side of your unit).
If the OP has a unit already, and the basic tools required, he could probably do what @frazpo linked to in his post.
KafxRadio
[QUOTE = "a417, publicación: 3510462, miembro: 27413"]
Tener un TP incluso sin una publicación hace que sea más fácil que algunos obtener acceso al punto discriminador.
Soldar con cuidado un cable y una resistencia a un punto TP marcado (aunque sea un rastro de superficie) y asegurarlo como necesita hacer con el -164 es mucho más fácil que algunos que requieren intentar soldar en la pata adjunta de un chip y luego quitar / Reemplazo de componentes como lo haría con un BCXLT180 / 280 (si también estuviera intentando usar la salida de fábrica debido a que no desea perforar un agujero en el costado de su unidad).
Si el OP ya tiene una unidad y las herramientas básicas necesarias, probablemente podría hacer lo que [USER = 101084] @frazpo [/ USER] vinculó en su publicación.
[/CITA]
but where do I put the other end of the resistor?
Paco-Jerte
You Member, Member!
34.0500° N, 118.2500° W
its pretty simple. I did a pro 164 and 97 and both the same for the exception of the TP4 tip.
Look here:
I am currently working on a Pro-136 which has a very tiny IC and have to be careful with the soldering on pin #11 ( NJM2552 )
