I need help with my pro - 528
epscanner
Texas
i bought this scanner at radioshack and love it
but just recently, i have had trouble listening to all the trunked frequencies in El Paso, Texas. I programed everything manually and it was working for a long time until now. The police department uses a type II motorola smartnet system. However i found out that they are changing it to a smartzone system, so is this the reason why my scanner isnt recieving the trunking channels??
Another reason might be because El Paso is right on the border with Juarez, Mexico, and they have had over 800 people killed this year, so the government sent soldiers to the city. It was just published in the El Paso Times that the soldiers and drug cartels are interfeering with our new wi-fi system downtown.
The El Paso police have not had any interference but is there a possibility that i cannot listen to the trunking channels on my scanner due to the interference in Juarez, Mexico???
N8IAA
Fortunately, GA
but just recently, i have had trouble listening to all the trunked frequencies in El Paso, Texas. I programed everything manually and it was working for a long time until now. The police department uses a type II motorola smartnet system. However i found out that they are changing it to a smartzone system, so is this the reason why my scanner isnt recieving the trunking channels?? Another reason might be because El Paso is right on the border with Juarez, Mexico, and they have had over 800 people killed this year, so the government sent soldiers to the city. It was just published in the El Paso Times that the soldiers and drug cartels are interfeering with our new wi-fi system downtown.The El Paso police have not had any interference but is there a possibility that i cannot listen to the trunking channels on my scanner due to the interference in Juarez, Mexico???
Do you have the El Paso City/County system programmed in EDACS mode? The Motorola system is analog/digital with most of the TG's being analog. I'm sure that your questions could be answered in the Texas forum with more info for you to understand what is what in that part of TX. :)
Larry
jrholm
Big Bear
It's probably due to a change in the control channels or the update to the smartzone system. You will have better luck asking in the Texas forum as it sounds more like a problem with an update to the system than a problem with your scanner
