Uniden BC796D APC0 25 Manual Online: programming conventional channels, Select A Channel To Program, Enter The Frequency, Assigning A Text Tag. Each Bank Can Hold A Mix Of Conventional Channels Plus One Trunking System. This Section Describes How To Store Known Frequencies Into...
www.manualslib.com
Page 37, bottom
Assigning a Text Tag
a. Use the scroll bar to select the channel you want to tag, then press E.
b. Use the scroll bar to select the letter, then press ▲/HOLD to move the entry position one
space to the right or press LIMIT/▼ to move the entry position one space to the left.
c. When you have entered the tag, press E to save the tag.
