Problem: Poor reception with BCD996xt on RS Sputnik about 30 feet in air, Quadshield coax 80ft run. But, using this same set-up with ICOM 2000H I get wonderful reception (the difference is amazing in fact). If it wasn't for the results with the ICOM I would be sure that something was not right in the setup. Now, I had tried PAR FM Filter with no change in results (sent it back). I now have the PAR 162.55 specific filter, with a little improvement in place as I was hearing some wx mixed in with some signals at times (also heard with the wx was pager at 152.48). I have not tried pager Filter as my reception issue is constant (not just when pager freq. is transmitting). I understand that a single band ICOM will have better reception than scanner but it just seems like there is still something that I am missing. In fact, I can get better reception with a back of set antenna on most local freq than with the antenna ots. I do notice some better reception in the nighttime hours (to be suspected I suppose). I just want some ideas from those that may have had a similar situation. I am not hearing any specific interference when scanning, just some major desensitivity across most bands. I am located in the Duluth MN/Superior WI area, very small metro area. I am trying to get a VHF control channel with my set-up. I am considering a yagi or, possibly bringing the antenna inside attic to avoid some of the desensing but what gets me is that, with ICOM, I can hear the CC Data with no problem. . What am I missing?
