jaymatt1978
I hear ITAC1 (851.5125) regularly here in Cape May and I think it's Delaware but I'm not sure I know the state moved to 700MHz so I'm a bit confused
Just to clarify, it was more than the name that was retired, it was the frequency itself. ICALL/TAC referred to the pre-rebanding frequencies in the 866-868 MHz range. 8CALL/TAC were created by subtracting 15 MHz from the existing frequencies, but they co-existed as the long drawn out 800 MHz reconfiguration (aka rebanding) took place.ITAC1 for naming was retired years ago.
Now known as 8TAC91
https://www.dhs.gov/sites/default/files/publications/National Interoperability Field Operations Guide v1 6 1.pdf
And you're right, many agencies try to program as many nationwide interop channels into their radios as possible, on as many bands as they have access to. All major manufacturers consider 700 and 800 MHz to be a single band for the purposes of building an RF deck, and so it's not uncommon to find both 7CALL/TAC and 8CALL/TAC frequencies in the same radio. In fact, many states have been just about harassing local agencies to program every nationwide interop channel into their radios, and list it as a requirement to obtain grant money for radios.
Delaware system is still 800 mhz. I have I tac programmed in I live on the west side. I haven't heard anything. There was a rumor that the state was moving to 700mhz but no signs of it
Delaware has two systems, the 800 MHz Motorola 3600 SmartZone system, and the new 700 MHz P25 system. It's a pretty safe bet that they will not be adding 700 MHz frequencies to the old 3600 system. Whether they actually start to migrate users off of the 3600 system and onto the P25 system is another question entirely, as currently it appears only the Dept of Corrections have active talkgroups on the P25 system.Some folks add 700 vs moving entirely to it, keep that in mind
