Icom: IC 208H Separation cable wiring diagram
K4EET
Chaplain
Severn, Maryland, USA
Does anyone have the wiring diagram for the OPC-600R or OPC-601R? I need to know what the wire colors are to the pin outs on the remote head side.
First, these are better PDF documents of the Icom IC-208H FM Transceiver:
Manuals - KO4BB.com
You can download the entire PDF to your hard drive.
Second, what exactly are you trying to do? If you have the cable, why can't you "ring out" the wires? Are you trying to find a broken wire in the cable? Why do you need the colors to begin with? Or just what?
Depending on what you need to do and if I can find my cable for remoting the head, I might be able to help you. I have the Icom IC-208H as a base unit and never did use the cable although I have it somewhere.
Let me know if there is something I can do that does not require cable disassembly which if I remember correctly, the connectors are sealed on each end...
73, Dave K4EET
