IC 2200H question.
ffemt25
Short Gap, WV
I have a 2200H and was wondering how to block out memory channels during scan mode. Thanks for the help ahead of time!
Bandingabout
This is done in SET MODE. Push[SETLOCK]or [MONI] until "CHS"-ON/OF appears, rotate [DIAL] to turn ON or OFF. Skip icon will appear as [CHS-ON]or skip icon disappears [CHS-OFF]. Push any key other than [SET] or [MONI] to exit set mode. Using the microphone, push [SET B(D-OFF)] or [ENT C(T-OFF)] until "CHS" appears, next use the arrow up or arrow down key to select on or off. Push[CLR A(MW)] to exit set mode. Also, see pages 41 and 74 in the owners manual.
WayneH
Forums Veteran
Super Moderator
Your master site
Since this radio is an amateur transceiver I'm moving this thread to the Amateur Equipment forum. The Icom forum under Scanners and Receivers Forums is for devices that do not transmit.
