I'm considering the ICOM IC-7300 to be used as a receiver only (for now). Does anyone know the current requirement when using it for receiving only, no transmit?
.9A standby, 1.25A max. audio per ICOM specs.
If you do this, you can turn the output power down to the minimum so if you accidentally hit the tuner button, or something that causes it to TX momentary, it won't draw very many amps. (less than 10)
I have the IC-7300 and it is a great transceiver. You will not go wrong buying this radio. The touch screen display is nice to use and easy to see. Sounds like you will be using this in a vehicle or with a limited power supply. If that's the case then do like edweirdFL stated and turn transmit power to lowest setting. I use the PS-126 Power Supply with my 7300.
Will the tuner be effective for receive? If so I might want to up the power supply to cover that.
Yes and no, for in ham bands when tuned it will help receive, but usually not so that you will notice much change. More easily noticed when moving to a different band and the tuner doesn't know the new frequencies yet. Being setup for the other frequency the tuner is more an attenuator until tuned. Down side is you will have to transmit for the tuner to setup new tuning setting. Outside the ham bands if you can for an external tuner put it in bypass. The rig will not transmit outside of the ham bands.
I would say for now omit the AH-4 if that's what you thinking of using. Get a wire outside of your living structure for now. A manual tuner can be used and you are peaking the receiver noise while adjusting the capacitance and inductance.
Mike
With a simple mod the 7300 transmits just fine outside the ham bands and the tuner works out of band also. Ideally you would never transmit anywhere without a license.
Not being familiar with this radio...what can cause it to transmit besides hitting the PTT on the mic?
