Ic f121s - PTT detect
thesavo
Schenectady, NY
Is it possible to program an f121s to open or close a relay on PTT?
I want to use power another receiver and turn it off when PTT is closed. I plan to operate with a receiver near the radio and don't want to blow the receiver on transmit.
Would I use the horn output?
I am a lineman for the county.
Doesn't appear that the circuit is there that you'd need.
the Horn circuit is for driving a horn when a radio call triggers the circuit.
There are radios that will do what you need, but the F121 was kind of a lower tier radio and probably wasn't designed to do this sort of stuff. There might be a place internal to the radio that you could connect to do what you want, but if it's not designed for end user access, the interface might be a challenge.
There are RF controlled relays that will do what you want. They'd go in line with the coax and trigger a relay to power down your RX, or disconnect the antenna.
Might be a good option to upgrade your radio, also.
Here's an expensive option:
Personally, for that price, I'd source a used Motorola CDM-750 VHF off e-bay. The 20 pin connector on the rear has programmable function pins that should give you what you need.
thesavo
Schenectady, NY
If I can get a cdm 750 with programming included, it may be worth the price.
Thanks for the name of the TR switch.
The next question would be, are there special considerations for connecting a voice keyer to a cdm750 ?
jeepsandradios
East of the Mississippi
Where are your antenna's and what receiver are you using ? I run 4 radios in my F150 along with a scanner and never had an issue other than minimal desence of the scanner while transmitting.
thesavo
Schenectady, NY
I have a quarter wave mag mount a few feet away. The radio can transmitted 50 watts. I wanted to use with another radio listening on other frequencies.
I am concerned about blowing the front end on the other receiver.
thesavo
Schenectady, NY
Yeah, you'll desense the receiver at minimum, risk blowing the front end.
You need separation between the antennas, unless your goal is to break something.
So should I forgo the switch and just have a different antenna a few wavelengths away.
12dbsinad
If the antenna's are 24+ inches apart you probably won't blow out the front end, but will certainly render the other radio useless during transmit from severe desense. Do you need to run the radio at full output power? if you can cut it back to 25w it certainly won't hurt anything.
