IC-F2721D MDC1200 Question
sam55671
NJ
I have a F2721D Mobile radio, and when I was programming it, I could not find where to set up MDC ID. Does anyone know where it is in the software? The Radio Specs show that the IC-F2721D does do MDC1200.
12dbsinad
Its on the left menu tab labeled as "MDC", a pull down menu. It sounds as though you have old version software, which didn't have it. Originally these did not do MDC, this was added later and was available on older radios with a firmware flash and a newer version software that added MDC.
What version is your software, and what version firmware is installed in the radio? If you hook up radio to programming cable then select clone then information.
sam55671
NJ
Here is what the info says:
Revision: 3.0
Sum: $60C4
Option: P25 On Board(Rev:2.8)
I am using software version 2.0
12dbsinad
Your radio firmware is relatively new, so that's good.
The software is old. I opened up my 2.0 to confirm and no MDC. You need updated software, latest is 2.2 and that's what I would try to find.
sam55671
NJ
Yeah, I have been trying to Locate V2.2 but haven't had any luck. Can you point me to the right direction?
12dbsinad
I get all my software from my local dealer. They order a factory CD for me so I have a legit copy. Other than that, not sure...
sam55671
NJ
I have a key for 2.2 but I dont have the actual file. Would you be willing to send me the .EXE file to my email for 2.2?
sam55671
NJ
I located a copy of 2.2, would you be willing to help me set up the MDC Chirp on my radio? I tried to do it but It is not working for me. ( I am a Motorola Guy, This is my first Icom)
