IC-F3400
Sergionic68
Douala
Good morning all,
I am facing a difficulty programming the ICOM IC-F3400DP radios. Jain installed the CS-F3400DP software with its product code and OPC1822 programming cable. Everything shows that it's fine and installed, except that I can't open the radio equipment. It shows me an "error" message that it cannot access the COM port*
- Check following COM port setting
- Programming cable connection
- Transceiver power is ON
Everything described in the error has been done and I don't understand why it doesn't work. Did I miss a setting somewhere???
Please help me
Thanks in advance
cancel
Try to hold P1 button and switch ON the radio. Hold the button until PC recognize radio.
