IC-F4026S RX on
I really ♥ Ø
Pt. Nemo
If any one have any idea why my radio have the rx allways on and the channel is idle.
Not sure what you are asking….
Is the green LED showing it's receiving a signal always on?
Are you hearing static constantly through the speaker?
leyendaoculta
Caguas, PR
The squelch is adjusted and fine, and the radio has no tx, the last day it worked fine was yesterday at work. After i come to home i powered on to put some frequencies for use and commenced with this problem.
I really ♥ Ø
Pt. Nemo
Well, if you are hearing static and the RX light is on, it's thinking it's hearing something. It's either interference or the squelch is too loose.
I really ♥ Ø
Pt. Nemo
But the radio has no tx anyway
Doesn't matter. The squelch adjustment is for the RECEIVE side. Even scanners have a squelch setting, and they don't even have a transmitter.
If you are hearing constant static and the green RX lamp is lit, then it needs to have it's squelch adjusted.
I really ♥ Ø
Pt. Nemo
The squelch is open all the time and no tx. No transmit to other radios
I think there's some misunderstanding going on here….
So, you are saying your radio is constantly showing it is receiving a signal, even when it's not?
— That is a squelch setting issue.
You keep saying "no TX". Not sure if you mean the radio isn't programmed to transmit, or it won't transmit.
— could be that it has a busy channel lockout function programmed into it. If it does, it will NOT allow you to transmit as long as the radio thinks it is recieving something. This is something that is done in the radio programming. It's call "BCL" or "Busy Channel Lockout" and it's there to keep radio users from transmitting while someone else is.
You need your squelch adjusted.
12dbsinad
Your squelch is probably set to zero, keeping the radio unsquelched constantly. You won't hear the noise if you have RX PL or DPL. Jack the squelch up like mmckenna recommended.
Keep in mind, Icom at one time sent radios with the squelch set to zero.
leyendaoculta
Caguas, PR
Ok the radio is programmed to transmmit i put the squelch to the max. The max value is 255 and i have the same problem the radio is receiving all time and no tx
I really ♥ Ø
Pt. Nemo
What happens if you remove the antenna? Does the noise go away?
Does the noise go away if you go to a different location?
I really ♥ Ø
Pt. Nemo
No the noise is present
Well, that means that there is either something wrong with the radio, or you have a very strong interfering signal nearby.
If the radio belongs to your employer, take it back to them and let them know there's something wrong with it. It's not something you can fix using advice off a hobby website.
