IC-F4026S RX on
leyendaoculta
Caguas, PR
The squelch is adjusted and fine, and the radio has no tx, the last day it worked fine was yesterday at work. After i come to home i powered on to put some frequencies for use and commenced with this problem.
Well, if you are hearing static and the RX light is on, it's thinking it's hearing something. It's either interference or the squelch is too loose.
If any one have any idea why my radio have the rx allways on and the channel is idle.
The squelch is open all the time and no tx. No transmit to other radios
I think there's some misunderstanding going on here….
So, you are saying your radio is constantly showing it is receiving a signal, even when it's not?
— That is a squelch setting issue.
You keep saying "no TX". Not sure if you mean the radio isn't programmed to transmit, or it won't transmit.
— could be that it has a busy channel lockout function programmed into it. If it does, it will NOT allow you to transmit as long as the radio thinks it is recieving something. This is something that is done in the radio programming. It's call "BCL" or "Busy Channel Lockout" and it's there to keep radio users from transmitting while someone else is.
You need your squelch adjusted.
12dbsinad
Your squelch is probably set to zero, keeping the radio unsquelched constantly. You won't hear the noise if you have RX PL or DPL. Jack the squelch up like mmckenna recommended.
Keep in mind, Icom at one time sent radios with the squelch set to zero.
leyendaoculta
Caguas, PR
Ok the radio is programmed to transmmit i put the squelch to the max. The max value is 255 and i have the same problem the radio is receiving all time and no tx
