I am a novice radio operator. I'm setting up an IC-5021 for my off-road rig. I have programmed one of the P buttons to operate as "Scan A Start/Stop" and another as "Scan B Start/Stop". I believe the Scan setting are factory other then I changed mode dependent scan to "On" as it seems easier to turn the scan function on and off. Have not set anything up in the "scan list" page as i am not sure what to do here. This radio came with the rig when I bought it.
My issue: When I select a scan list, scan 1 seems to be the only one that scans. I don't even know what the difference between the 10 scan #s and zone selection are?
Scan 1 does scan threw all 3 zones of channels i have programmed. I would like to create a custom scan list. My issue is: when i turn scan 1 on it scans until it reaches a NOAA channel then stops scanning as NOAA is always transmitting. I would simply like to scan without stopping on NOAA . So i would like to exclude NOAA from the scan list.
Any help would be great.
Thank you
Thank you
