IC F5061 / CS F3160/F5060 2-Tone
alexjusti
Dalzell, IL
I'm programming an IC-F5061 and I'd like to configure one of my programable buttons to transmit a 2-tone sequence. I found a "Call" option under the programmable button choices but I'm unsure of what this does. Will this cycle through my selective call options and allow me to transmit or do I have to do something else to achieve my end goal?
Vern
Union County, GA
I haven't used the 2-Tone feature but in looking at the cloning software (ver 5.3) it appears that you'd at least need to preset tones on the table found under "2-Tone" > "Code CH" on the TX side. There are slots for 10 sets of 2-Tones. There's room to add a 12-character text label for each set of tones.
Also, on the "Zone" page where you enter frequencies, etc., there is a section down to the right with a green label "2-Tone" at the top. Enter the proper number (1-10) in the TX column to ID which set of tones (from the above 2-Tone table) that you want the radio to Xmit.
That's my best guess anyway. Best of luck with it.
73 de Vern
