IC-F50V Programming Issue
johnhicks
Inuvik, Northwest Territories, Canada
Trying to program the IC-F50V and I can read ok, but cannot seem to write at all.
Model: LMR
Version: 3.6
Using CS-50VMM Rev. 3.1.1
Trying to do this myself to save some money for my SAR group and any help would be appreciated.
jeatock
090-45-50 W, 39-43-22 N
Are you sure the radio is a "V"? MM will read but not program non-V MDC radios.
It is not a connection issue if the radio heard the software command to clone to the PC..
TRNcommLLC
Monongahela, PA
Also make sure it has the MM Firmware installed.
If not you will need the MDC version of the software.
All newer F50V's have the MM firmware installed (2014 and newer).
Check Your Firmware
To determine which software your radio is capable of using, check the firmware.
1. Press and hold the Up Arrow and P3.**
2. Switch the power on.
The display will show the firmware version.
Software that has a three digit version is not compatible with firmware with a two digit
version; Software with a two digit version is not compatible with firmware with a three digit version.
Post what you have and we can tell you what software you need.
John
