IC-FR4000 Locks Up In Transmit
AB5CC
Durant, OK
Just purchased this new FR4000 for my work. Locks up in transmit. I went in and lowered the receive sensitivity and now it still locks up on all but very short transmissions. Sometimes, it will stop transmitting if you will key up another radio on the frequency. Tried lowering power to 10 watts with the same result. This unit came with the factory installed 6 cavity duplexers. I have tuned them with my Motorola service monitor. I brought in another radio tech and re-tuned them, with the same results. Any ideas?
cabletech
Puget Sound
If it is new and having this problem, then either return it to where you got it or send to Icom on warrenty.
Do not mess with it.
If the unit is used but new to you then I would still check and see if it still has a factory warrenty and still ship it off.
AB5CC
Durant, OK
Thanks for the fast reply. We got it a year ago and the project got put on the back burner. I will check to see if the warranty is out. I have a friend who works for the fire department up the road and they had the same problem with a FR3000 and he had to back off the receive sensitivity to get it to act right. He said they told him it was approximately 1db for every 10 units. I reduced this one from 83 down to 65 and it still isn't right. I haven't hooked the service monitor up to see what the RX sensitivity is now.
