IC-FR4000 - No Audio
N0JKY
Hello,
Strange issue with this IC-FR4000-3 Repeater. Firmware 1.5
After programming a simple repeater RX/TX Pair, I'm not getting any audio returned when accessing the repeater, just a carrier, and a brief Squelch Tail. (Using 2 HT's for testing)
Searching this Forum, I did find a thread to check PCB CP1 and CP2 circuits for cuts due to UT-109/UT100 Installed Options.
Both CP1 and CP2 appear untouched.
Have anyone run across this and/or have any suggestions on what else to check?
Thank you in advance.
Dan
jeepsandradios
East of the Mississippi
So a bit more info is needed. Does unit have duplexer installed and tuned ? Antenna's on repeater or dummy load. Does it have a hand mic to test with ? I have seen desence do exactly what you describe.
N0JKY
I do have a duplexer that was sent out for tuning on the operating frequencies, an Icom IAS RDN 450B. Vendor indicated a perfect tune, no issues, but again this was done via, USPS. Not ideal I guess.
I tried the Duplexer externally, and I also tried using 2 external roof mounted antennas, approximately 12 feet apart.
Same results, carrier, but no audio. I do have a hand mic I can try, and also a dummy load.
Power output into a Dummy load indicates 25W, and is adjustable via., A06 Power in adjustment mode. No other adjustments were made.
How do I verify if it is indeed desence?
Thank you for the quick reply.
