Well,
88.236 is it. True- the interface is clunky, has some parent/child window stability issues.
It would be nicer if the program could just have all of its function in a single window with three panes:
| File Tools Menu3 Menu4 . . . . . . . . . . . . . . . . . . . . |
| . . Receiver 1 . . . . . . . . .| . . . . Receiver 2 . . . . . . |
| (Tab1) | (Tab2) | (Tab3) | (Tab4) | (Tab5) | . . . . . |
| | . . . . . . Data . . . . . . . . . . . . . . . . . . . . . . . . | . .|
*** CHIME IN HERE ANY TIME JAY (I know you read this forum)!!
Also, there is no manual to go with it, you figure it out as you go.
However, the way I do it is the following...
Getting started:
*Make sure you have the receiver type set for PCR2500, not PCR100 or PCR1000 and ports are set correctly.
*No discriminator tap necessary, just plug in an 1/8" to 1/8" mono audio cable between the Packet jack FOR THE SECOND RECEIVER and the line-in of your soundcard.
* At this point you must understand that you will now have two audio feeds from the second receiver, ONE from the built-in USB audio driver installed by the Icom software and THE OTHER from the line-in in the sounds card.. At some point below, you will be hearing the control channel coming out your speakers through both of these paths. You will control the volume for these audio paths in two completely different areas: 1) through TrunkPCR and 2) through the Windows Audio Mixer which you access through the Speaker Icon in the icon tray (make sure you have "Advance Controls" enabled in the Mixer to be able to drop the volume slider for the line-in).
Setup Trunking:
1) Create a new Bank and give it a title.
2a) Add a channel to the new bank, and set the frequency for the CC, Press the [Store] button.
2b) Repeat step 2a for as many CCs needed
3) Add one last "Dummy" channel (any frequency at all) that you know won't have audio carriers on it. (You know why later)
4a) The Settings Menu will now apply to the currently selected bank <-- IMPORTANT TO REMEMBER
4b) Select Trunk Settings to setup the trunking parameters for the current bank. (Hopefully you understand how this part works and does not require explaining)
4c) Under the Sound Card Setup make sure your recording device is the Identifier for the sound card that will do the decoding through line-in (preferred) or mic-in. At this point, you will not yet know whether whether the inbound audio from the CC will be Inverted or not, so you may need to come back to this step later.
Trunk Tracking:
1) Open up the second receiver for the 2500 by pressing the [Dual] button. A Child window should appear.
2) Select the Bank you just created by clicking on its tab for the second receiver. NOTE: The Bank tabs for the second receiver are independent of the primary receiver's Bank tabs (make sure you have both receivers' Banks match).
3a) Using the Channel Up/Down arrows on the second receiver, select the channel whose CC provides the strongest S-reading on the meter (and/or by monitoring it through your soundcard)
3b) Once you are tuned and listening to a CC, do yourself the favor and turn the volume ALL the way down on the second receiver so you don't go nuts listening to that incessant chatter.
4) On the PRIMARY RECEIVER, use the Channel Up/Down arrows to find the "Dummy" channel you programmed earlier so the it is quiet while idle.
5) Press the [Trunk] button to start tracking.. At the STATUS WINDOW OF THE SECOND RECEIVER, you will see the two values thrashing about:
-- Ration of 1s to 0s (binary CC data), and
-- Percentage (%) of quality, recovery of the CC datastream based on how the program decodes it
NOTE1: The ratio of 1:0 should always be floating between 40-60 AND,
NOTE2: The data recovery rate should always average above 80% for quality decoding to happen.
CRITICAL NOTE!!: If you are not seeing high recovery rates, you may need to do one of two things:
A) invert the polarity by going back to the Settings window and checking the box off. This will apply to the currently selected Bank.
B) Adjust the RECORDING INPUT VOLUME adjustment slider by clicking on the Options>Properties>Recording ROUND RADIO BUTTON UNDER THE WINDOWS MIXER (through the speaker icon in the windows tray). In other words the GAIN of the audio coming into the soundcard, not the volume of that audio coming out the speakers.
C) A combination of both A and B
6) If all of the above looks good, then you should be hearing the trunked system. If you are not, make sure you press the [Search] button.
7) Also, press the [Dump] or [Control] buttons to see the live action of the trunking data flying past as message are being sent by the controller in real-time.
8) Minimized the second receiver's window as it just gets in the way and you won't need to do anything else with it unless you're tweaking and changing CC channels.
9) Enjoy watching the trunk monkey smiling at you! (if you have the "See whose talking" option turned on in the settings).
Hope this helps get you up and running!
