IC-R10 Distortion in audio on AM SSB and NFM
jim44444
Hello, recently purchased a second hand IC-R10 receiver but there seems to be a problem with the audio distorting when i turn up the volume button. It works ok in WFM mode when listening to radio stations. I've made a couple of videos of it happening.
Distortion using USB
Distortion using NFM
Tried enabling the ATT and still happens. Any help would be much appreciated.
kruser
Well Known Member
W St Louis Cnty, MO
What does NFM mode audio sound like when you are tuned to an actual fm or nfm signal like say a NOAA (162.xxx) broadcast? That's assuming you are in the US and within range of a NOAA signal of course. Or use an active public safety frequency if NOAA does not exist at your location.
For SSB modes, does the audio distort in both upper and lower SSB modes?
jim44444
Tried listening to people on 2 meters and 70cm in NFM mode still the same distortion with a buzz just before the distortion kicks in. For SSB it does it in both LSB and USB and AM. Also tried on an external speaker and same thing happens.
kruser
Well Known Member
W St Louis Cnty, MO
I know the factory service manual can be found online.
I'd probably start there and go through the SM and see if you can find a common component to all the bad modes or possibly an entire circuit section that handles all the bad modes.
It may not be that hard to figure out what's responsible for the problem with a copy of the service manual.
Good luck with it!
Ubbe
Stockholm, Sweden
As it is dependent of the volume setting it could be a leaky capacitor. When you turn up the volume you are changing a DC voltage that the capacitor should block. It must then be directly coupled to either the top or the wiper of the volume control. Could be the C958 in the main logic board. Schematics are at the mods.dk website.
/Ubbe
majoco
Stirrer
New Zealand
Have you tried listening on earbuds or headphones - I'm suspecting the speaker may be damaged.
jim44444
I have found out when the rechargeable batteries are nearly empty the distortion goes away then comes back when i recharge them.
kruser
Well Known Member
W St Louis Cnty, MO
Probably because the low batteries can't deliver the current and voltage needed to the audio stage that a charged set of cells can deliver.
