palmerjrusa
Are you going to get one at $559...$110 more expensive than EU
Yep, I preordered it weeks ago from HRO...
Just checked with a sales rep., it's coming from their Sacramento outlet...
Hope you can return some or you, too will have drawer of not so useful antennas🤪😃I received my Comet AB35WS today and....it is another terrible disappointment, it is just as bad as the Watson 901. The signal sticks dual band is so much of a better performer and the Icom FA-B02AR coming out on top. I think I have finally found my king of handheld antennas...the Icom FA-B02AR. If I need to improve the reception any better, I will bring out the Taco D-5076 mounted on a tripod.
Tell me about it, I have loads!Lol…I think I might be joining that club…Drawer full of under performing antennas…
The FA-B02AR antenna is the stock antenna for the ICOM A25C which can only transmit on 118 to 137 and receive on 108 to 137 - I am guessing it is "tuned" to some degree for that range - have you had a chance to test it on the UHF frequencies (225 to 380) to see how well it can receive in that area? Thanks
What do you believe this feature to do? My understanding is that it is suppose ignore digital noise. Are you saying it doesn't do that?I'm confused about the VSC (Voice Squelch Control) setting, When I toggle it on, it doesn't hold, either on particular memory channels or during a scan. And when I edit a .csv memory channel file and specify that it's on, it doesn't work. I know it is said to work only for FM and FM-N, but I can't get it to work at all. Has anyone successfully enabled it?
It does not. And the "VSC" flag appears on the top right corner of the screen for a moment and then disappears.What do you believe this feature to do? My understanding is that it is suppose ignore digital noise. Are you saying it doesn't do that?
Fair enough. I'll play with it and let you know what happens on mine. What digi are you trying to bypass -- DMR/NXDN ?It does not. And the "VSC" flag appears on the top right corner of the screen for a moment and then disappears.
Yes, those modes plus junk noise like GPS bursts from survey crews on itinerant freqs, plus burps from mesh devices on MURS, etc.Fair enough. I'll play with it and let you know what happens on mine. What digi are you trying to bypass -- DMR/NXDN ?
Yes! Exactly what I was trying to say in my post #173 above…good advice with some good recommendations !FWIW, I tried a few other antennas. It's going to nearly impossible to find a broadband rubber ducky antenna that covers 118-470 megs.
My Remtronix REM-842B is not bad but it's very thick and fairly large for the R15. They do sell a SMA version. That will get you tuned VHF Air, VHF Biz, UHF Mil-Air and UHF Biz bands.
SMA VHF/UHF/800 MHz REM-842S REMTRONIX Triband antenna | Scanner Master
SMA VHF/UHF/800 MHz REM-842S REMTRONIX Triband antennawww.scannermaster.com
(The REM-842B works quite well for other scanners -- trunking, etc. Just note that it's not a small antenna.)
My best antenna recommendation is this:
There's a clone of the Diamond telescopic on Amazon for $16 but I have no experience with that model.
With the Diamond fully extended, you'll get VHF Air and UHF Mil-Air. If you collapse the first top section, then you'll shift up a bit in frequency which brings in VHF HAM/Biz/Marine & RR. This does shift the UHF Mil-Air to the upper portion -- like 280-380 megs.
The overall point is that with the thin, telescopic whip you will have a tuned antenna for anywhere on 118-470 megs. It also has the tilty-flippy mechanism so that may be a good selling point too.
PS. Watson also makes a telescopic whip but I don't have that model. I do own both 881 whips and they're OK but again, not broad enough for full coverage.
