Just updated the IC-R15 firmware to v1.02, we will see if there are any changes/improvements. Very straight forward & simple process...but then again, it is Icom, wouldn't expect anything less.
I don't see that firmware on the ICOM web site... unless it's on the ICOM Japan site and not the US web site?Just updated the IC-R15 firmware to v1.02, we will see if there are any changes/improvements. Very straight forward & simple process...but then again, it is Icom, wouldn't expect anything less.
There were no "fixes" in the new release.Just updated the IC-R15 firmware to v1.02, we will see if there are any changes/improvements. Very straight forward & simple process...but then again, it is Icom, wouldn't expect anything less.
Did you try the R15 with the A25 antenna? It'll act like a BP filter since it's tuned to VHF Air.It beats my Icom A25C hands down when it comes to air band. No comparison, I am hoping Icom’s next generation of VHF air transceivers will incorporate all the tech and features of the IC-R15
Yeah it would be nice but not necessary. I found these on Amazon. They work quite well and make it seem like it's part of the antenna.The FA-B02AR is the stock antenna for the IC-A25 series of transceivers. I would love Icom to make a SMA version of the FA-B02AR. It would be great for the R6, R15 and R30
The Diamon SRH-1230 is the easiest to find. I bought mine from a local retailer here in Australia. The others mentioned, plus a few other like the Comet CMY-AIR1, I have bought from Japanese retailers. Airband monitoring is very popular in Japan, to the extent Comet has partnered with CQ Ohm (a Japanese ham retailer) to make specialised airband antennas.From a non-airband person(minimal listening, not near any major airports) why is it so difficult to find and purchase some of the antennas mentioned above? Mostly available overseas. Is airband more popular there?
Plus too damn expensive. For $600 it better do every mode known to man including phase II. And the tuning steps? Pass.The tuning steps question could be an important one if you are trying to monitor a U.S. VHF land mobile licensee. With the advent of "narrow band", VHF land mobile frequencies (roughly 150-173 MHz) are being assigned on a 7.5 kHz channel spacing. If your radio doesn't have 7.5 kHz or 2.5 kHz as available tuning steps, you may have difficulty tuning to the exact frequency of your listening target.
Most Japanese radios intended for the amateur radio market do not have 7.5 kHz or 2.5 kHz tuning steps. Looking at top of the line models:
Icom ID-52 5.0/6.25/10/12.5/15/20/25/30/50/100/125/200 kHz plus 8.33 kHz on the air band
Kenwood TH-D75 5.0/6.25/8.33/9.0/10/12.5/15/20/25/30/50/100 kHz
Yaesu FT5D 5.0/6.25/10/12.5/15/20/25/50/100 kHz plus 8.33 kHz on the air band and 9 kHz on broadcast AM
Which brings us to the IC-R15 which has 5/6.25/10/12.5/15/20/25/30/50/100/125/200 kHz plus 8.33 kHz on the air band.
Compare this to the IC-R30 which has 0.01/0.1/1/3.125/5/6.25/8.33/9/10/12.5/15/20/25/30/50/100/125/200 kHz.
I think that the IC-R15 misses the mark when it comes to tuning steps.
The r15 allows alpha tags to be added to any memory channel, although what is displayed and in which order is configurable. Both memory channels can display the stored names when in dual watch, just as for the ID52.Does the R15 allow alpha tags on any memory channel? I've only ever seen pictures with an alpha tag on a freq when in "Simple Mode" (described here), meaning you see the little airplane (for example) when picking airband in Simple Mode.
So can you program alpha tags on any of the 2000 memory channels? If so, what's the alpha tag length? And do alpha tags display on both bands when in dual monitoring mode (although this looks like a no) ?
