srletend
I'm considering the purchase of an IC-R8600. A few specific questions related to L-band satellite monitoring. Currently I use an Airspy R2 with SDR# for Jaero and STD-C. Also using a HackRF with iridium-toolkit on a linux box. Both with an active L-band patch antenna powered via bias tee.
My questions:
1. Can the R8600 provide bias tee power to an active antenna? I believe the answer is no. If that's the case, do you need an external power inserter? Would this work with the R8600?
2. How well suited is the R8600 for picking up an Inmarsat-C NCS (e.g., AOR-E at 1541.45000) signal and feeding a decoder such as scytale-C? I'm thinking the 12khz IF output would be fed to the decoder. Should I expect to see better performance than the Airspy R2/SDR# method?
3. Can the R8600 be used with iridium toolkit? Currently that process takes in 10mhz bandwidth from the HackRF and sorts out the packets. Would I need to use the I/Q output from the R8600? Could the 10.7mhz IF output be used?
I know these are very specific questions and I'd have a bunch of fun figuring out the answers on my own--I just don't want to spend what it takes to learn the R8600 is not well suited to the type of L-band monitoring I want to do...
Thanks in advance for any insight in satellite monitoring with the R8600!
My questions:
