IC-R9000 Delta F Scan Problem
woodpecker
Hi folks,
I have just bought a second hand IC-R9000, when I press the delta F scan button the 9000 reports "Logic Check" on the screen. Sometimes it will just return to the previous settings and sometimes it hard resets the radio erasing all memory channels etc. I have performed a reset as per the manual and its the same, when doing a logic check as per the manual it reports all ok. When it resets the radio it shows a logic check screen with an error against "Data" and some numbers like "0008ch".
Any ideas please?
Thanks.
bagmouse7
NC, USA
I took a quick look at the R-9000 service manual and I don't really see a good troubleshooing section for tracking down these logic errors.
This one is probably going to have to go to Icom in WA..
Good luck.
