IC4161DT and NXDN
Jimbo695
Hauppauge NY
Hi folks. I set up a zone for local NXDN frequencies and populated the channels. All I receive is the same distinct NXDN noise that we get on our scanners; the unit is not decoding the stream. Can anyone help me with what must be incorrect program settings, please? Thanks, all.
luckygecko
US
Do you have the channel set to mixed or digital in CS?
When you look at radio information tab in the CS does it show the digital option? I know you said the Radio was DT, but if it has an unknown history the option board could be missing.
I would assume it mutes encrypted traffic, but I don't know.
Are you sure traffic is NXDN and not DMR?
I know some of these are obvious, I mean no insults.
buddrousa
#1 Do you have the correct RAN programmed?
#2 Are any Talkgroups used?
#3 Is this a NXDN conventional or NXDN trunking system?
Just having a NXDN capable radio does not work like a scanner you have to have the correct hardware and programming information for the system you want to use.
I also see your county only has listed a NXDN 9600 Trunking system and a NXDN 4800 Trunking system a few P25 Trunking systems and 2 Motorola TRBO Trunking systems.
Jimbo695
Hauppauge NY
Luckygecko and Buddrousa, thanks for helping me out.
It's the 4161DT model. I have the frequencies programmed in as digital. Each should be a conventional and not trucked but I suppose some of them may be. Even if they are trucked, couldn't I get whatever transmission comes over the programmed frequency even if I couldn't follow the conversation?
I programmed zero for all RANs since I learned that zero should allow all signals to pass through. No idea how to determine the RANs if I need them.
Thanks again!
