I don't know if this is the correct place to post as I know this has been covered, but after reading through several different threads, and trying multiple programming setups, it has become painfully obvious that I don't know what I'm doing.
Anyways I'm trying to monitor Pomona, CA from the Ontario/Upland area. I am using a pro 96 with arc 96 software and RR import. From the database import pomona always comes setup configured as mot., and picks up nothing at all. If I change to apco25 the scanner will stop on the control channel with noise, and every so often on one of the other frequencies with digital gargled noise with intermittent clear audio. I have ran the setup on the pro96com software and I dget alot of information that I still don't know what to do with. I have tried several different custom tables, which I have found here, all with similar results. Do I need a different scanner? Or am I doing something wrong? I am very frustrated at this time, as I have spent the better part of the last few days on this with no luck. Thank You in advance for any information regarding this matter.
