icom 208H
castking
Maple Ridge, British Columbia. Canada
I have a Icom 208H radio. I would like to know how to change from bank to Bank using the icom HM133 microphone. I understand changing the banks using the face plate but a little confusing using the mic
Thanks for your help
Terry
davedaver1
Hillsborough County, New Hampshire
From the manual:
1) Push [MR/CALL] to select memory mode, if desired.
2) Push [FUNC] then [MONI 1(BANK)] to select memory bank condition.
• Bank’s initial blinks
3) Push [UP][DOWN] to select the desired bank, A to J.
• Only programmed memory bank can be selected.
4) Push [CLR A(MW)] to set the bank.
• Bank’s initial stops blinking.
5) Push [UP][DOWN] to select the desired contents in the bank.
• No channel numbers are displayed for memory bank operation.
6) To return to regular memory condition, push [FUNC], [MONI 1(BANK)] then push [CLR A(MW)].
It looks more complex than it really is. Once you try it a few times it will make sense quickly.
