Hi Guys,
I programmed some repeaters into my radio, all fine well and good, however I cant seem select and enter a memory freq.
So for example, I programmed three repeaters on three memories, 1, 2 and 3. If I am memory 3 and I then hit the memory select button, rotate the dial to the desired repeater say memory 1, I cant enter it. It seems as though I do a memory transfer when I hit the memory key too long to try getting it to enter memory 1.
How the heck do you accept or enter a memory freq after rotating the dial and selecting it?
The other problem I have is the radio goes blank for a fraction of a second when I am listening, the techie at Icom says its because priority scan is enabled, I followed the manual but cant seem to stop this from happening. Reading what they said, it seems like it is deactivated.
Your input will be much appreciated.
73
73
