Looking for info on using the RF Tap Board on the Icom-7100
There is a RF line in the Icom-7100 that you can tap off to run to an SDR play. The problem is it all so has Low level RF on the Line when in transmit.
so i want to use RF Tap Board help to block this RF from getting in to the SDRplay.
This is the info I found but I would like to have some thing in there to protect my SDR play.
I want to use this The PAT V RF Tap Board it is the same board I used in my TS-2000 with my SDRplay
all so I need to find a control line on the IC-7100 that will go high when in receive and low when transmitting.
